Spark Plug angle
ericwwreckless
Spark Plug angle
Post by ericwwreckless »
Does anybody know the angle of the spark plug relative to the head in these engines? I need it for a milling machine setup.
'74 Ducati 750GT | '78 MZ TS250/1 | '86 Morini Kanguro | '97 Honda VFR750
In the high latitudes of Finland, in the parching heat of Africa, under the most different operating conditions these motor-cycles run to the satisfaction of their owners.​
ericwwreckless
Re: Spark Plug angle
Anybody?!
tfel63
Post by tfel63 »
I feel the need to fill the void but without any practical advice of any substance! Would some sort of engineering protractor-type thing work?
Glennh
Post by Glennh »
Re. your spark plug angle.
Assuming you have another cylinder head with a good plug thread, why not machine the insulation from a spark plug, bore the spark body to take a suitable straight rod, insert aforemtioned rod through spark plug body and clamp the rod in the chuck on the mill. Then position suitable blocks/wedges under cylinder head face and fix them in position. Remove good cylinder head and rod from mill and replace with duff head. Spark plug angle will have been established via previous steps.
I recall a similar method was used for exhaust thread repairs and there is a you-tube clip showing the procedure.
Vitesse
Post by Vitesse »
No idea but you could ask on one of the Whatsapp groups. Benjy and a few others can't help themselves but answer all the obscure questions!
Edit I've asked and nobody knows. That's why you've had no answer.
General view is to either insert threaded bar and measure it or, as the heads are flat, just mounting in a mill and set the angle to what is currently there. Most people use Timesert or specific plug thread repair kits.
Is this actually for a plug thread repair? Or some other job? It might help you get the info you need!
ericwwreckless
A flurry of responses - thank you comrades. The repair is on a (new to me) Kanguro cylinder head where the timesert wound out with the plug when I was changing plugs. Since a new timesert won't work alone, it needs opening up and an aluminium insert fixed in place before the new timesert. Much more hassle than I would have liked from my new bike!
Why not just fit an aluminium insert and tap that?
ericwwreckless
That's probably what will happen, it would be easier knowing the original angle. I thought I had copies of the technical drawings but I 'misremembered'.
ericwwreckless
Glennh wrote: 15 Oct 2025 15:14 Re. your spark plug angle.
Top tip - thanks.
One a different bike, with very accessible cylinders, I used a Spark Plug repair kit from UniThread to fit a wire insert. I used Loctite 266 and left it a few days. You have to break the insert tang off which I did in situ but captured it with a strong magnet on the tool at that moment. I have had inserts wind out on other minor repairs but my own fault for not allowing full cure of the loctite, so the bolt bonded.
I used to think adding loctite to wire inserts was a good idea. Then when talking to a rep from Loctite, and he was particularly speaking about their new anaerobic range of thread locks, he said not to use it as the agent will leak through and grip the plug or bolt/stud. This will make the insert come out next time the plug/fastener is removed. He also said what the Rolls Royce reps told us about helicoils, the hole should be scrupulously cleaned (the fresh cut thread for the insert) using brake cleaner etc. This will allow the wire insert to work as designed and grip the parent material. I use Recoil and Uni-thread inserts regularly and following this advice they don't need looking at again.
Timeserts are another good solution but cost more and I think need more surrounding diameter of parent material.
That info about Loctite is interesting.
Parker3865
Post by Parker3865 »
A bit late but...
I had the plug out of my 250 2c and used a piston depth gauge. Photo and some CAD for the following:
20251114 Plug to head angle sm.jpg (355.73 KiB) Viewed 4337 times
There will be some inaccuracy due to drawing the lines and parallax with the angle I held the phone at, but may help someone in the future.
