Dellorto VHB25bs carb body
Morinimatt
Post by Morinimatt »
As in the description i need a carb body for 1975 morini 3 1/2 sport, snapped the idle screw in and extractors wont see it out.
Matt
FatherB
Re: Dellorto VHB25bs carb body
Post by FatherB »
Hi Matt, make sure it's from a 4 stroke. Lots of VHB 25BS are around as fitted to Benelli/Guzzi 250 2 stroke twins. They look identical but have different internal drillings which really throw off the mid range carburation.
Morinimatt
Will do thankyou, is it obvious in a side to side comparison? I have found one on ebay however its a complete unit and no pictures of internals
hombre
Post by hombre »
I might have a couple, but of a later model, so with breather tubes etc. If you are not after the original looks they might be of help?
Post by simonnorthroad »
Hi Matt,
ive got one or two complete here in the UK if you want. (Bath)
Simon
tel: 07788 442155
ianlucas006
Post by ianlucas006 »
Hi Matt
Almost certainly got one. Will have a look tomorrow if the flu lurgy has abated a bit! Thanks Ian
