Fork Brace and Mudguard for the Morini LSR
smotorboy
Post by smotorboy »
I haven't posted any updates in a while, so here is one of the many components just completed...
I had been advise that these bikes need a fork brace at very high speed,,, so now it has one,,, along with a mudguard to keep the salt spray down a bit...
Robert in California
smotorboy
Re: Fork Brace and Mudguard for the Morini LSR
Post by smotorboy »
OOPS ! I post this in the wrong section,,, the mudguard is not for sale,,, but if you like the looks of it , I might be enticed to tell how to make one just like it...
Robert
nickst4
Post by nickst4 »
smotorboy wrote:OOPS ! I post this in the wrong section,,, the mudguard is not for sale,,, but if you like the looks of it , I might be enticed to tell how to make one just like it...
Robert
And that is not a fork brace but a steering damper. Otherwise, it looks very smart!
Nick
smotorboy
Post by smotorboy »
Two different things,,, the fork brace is the heavy bracket that the front mudguard is attached too.....A fork brace keeps the fork legs from "flexing out side-to-side" in the middle which can impart a serious instability into the front wheel,,,, which the steering damper would then have to deal with.....Best to stop bad thing from happening in the first place than have to deal with them when they appear....
nickst4
Post by nickst4 »
smotorboy wrote:Two different things,,, the fork brace is the heavy bracket that the front mudguard is attached too.....A fork brace keeps the fork legs from "flexing out side-to-side" in the middle which can impart a serious instability into the front wheel,,,, which the steering damper would then have to deal with.....Best to stop bad thing from happening in the first place than have to deal with them when they appear....
Sorry, but your 'fork brace' is more of a tuning fork; it will have little capability to hold the forks parallel because it is bent into a curve. Effective fork braces are massive straight fixings, rigid (but adjustable for initial installation) that generally fit above the mudguard and clamp around or to the very tops of the sliders.They are rarely necessary except for bikes with single front discs, where heavy braking may twist the forks.
We don't want you having a high-speed accident just because you've not quite got it right!
Good luck with the LSR work.
Nick
smotorboy
Post by smotorboy »
Keep me straight Nick,,, I'm needing all the help I can get to stay safe......
Yes, the little "U" bracket is no match for a proper billet type brace, but it does have a little positive benefit. I have a 450 Honda that has the same fender & bracket, and when I took them off to go for the total "Cafe" look, that darn bike would shake its head over rough spots...I put that fender & bracket right back on
Some of the bike guys in my club run TWO steering dampers at El Mirage,,, I'm looking into everything...
Robert
