Carb o ring
cliveo
Carb o ring
Post by cliveo »
Does anyone know where I can get two o rings from
Re: Carb o ring
Hi Cliveo
This is a global forum so it would help to know where you are.
In the UK the best for dell orto is Eurocarb
https://www.dellorto.co.uk/
Look for vintage carburettors
Daddy Dom
Re: Carb o ring
Post by Daddy Dom »
I'm in NZ and I use the same supplier. They have almost everything for our carbs, I believe.
DD
AntietamClassicCycle
Re: Carb o ring
cliveo
Re: Carb o ring
Post by cliveo »
Thanks All for your suggestions
I have now sourced carb gasket kits which have the o rings required
